Need the collective wisdom of the forum elders.
Old Feb 2, 2019 | 10:53 AM
mln01's Avatar
Your DII can go 75-85. Who knew?
One way to address the problem would be to not drive faster than 74 mph. 🙂
Old Feb 2, 2019 | 12:10 PM
Ben Matheson's Avatar
If you aren't doing 80 on the interstate down here you'll get rear-ended
Old Feb 2, 2019 | 12:16 PM
Have you swapped the tires front to rear to see if the vibration follows
Old Feb 2, 2019 | 12:26 PM
I will do this next I was concerned the steering damper would mask things if moved up front but I guess it should make a noticable change even so
Will report back after rotation
Old Feb 2, 2019 | 12:52 PM
zuke's Avatar
Has it ever been in a front corner collision? I had one that acted similar due to a slight kink in the frame.
Old Feb 2, 2019 | 06:55 PM
Extinct's Avatar
I had a chevy truck throw a ring gear tooth once, immediately started whining like crazy. Bought a non-driving disco once where the middle shaft in the transfer case had the retaining ring come off and the shaft walked out until the gears were grinding I would check your differential fluids as well as the transfer case fluid, check the rear diff flex joint. If none of that checks out drop your diffs one at a time and check the gear conditions.
Old Feb 18, 2019 | 11:59 AM
Update and resolution. Found a really good tire shop with a road force balancer to really check tires and rims. Found a bent rim that was hard to see unless spun at just the right speed. Swapped the rim with an extra I picked up and now she's smooth as glass.
Old Feb 18, 2019 | 06:11 PM
Extinct's Avatar
Thanks for the follow up, good to hear you found it and not too serious.
san988
Nov 27, 2025 02:36 PM
aemnky606
Feb 18, 2019 04:12 PM
Spencerfitch
Sep 22, 2012 06:50 PM
javoli001
Oct 22, 2008 06:23 PM
LiftedRover96
Feb 7, 2006 10:41 PM
