Need Diagnostic Help - ACE System Noise? - Clunking with Body Roll
Old Nov 25, 2013 | 09:13 AM
TripleThreat's Avatar
Finally circling back around on this... I've had this solved for quite a while, but waited to post until I'd driven the Rover enough to be sure it is solved...
I was able to find the source of this noise...
The sway arm links that I purchased were aftermarket from Atlantic British.
They were the source of the noise and one ultimately failed - the Ball pulled completely out of the Socket... Atlantic British sent me a replacement... It failed as well...
Atlantic British then sold me OEM Sway Arm Links and refunded my money for the aftermarket versions...
The OEM replacements solved the problem...
The aftermarket versions were not strong enough to handle the forces created by the ACE package (and yes, Atlantic British knew that I had a Rover with the ACE system when they sold them to me). They are clearly under engineered.
I probably didn't need to replace the Ball Joints, but as a result of trying to track down this noise, I ended up replacing them, so the suspension should be in pretty good shape.
Next up is an Old Man Emu lift, shocks and some larger tires...
Old Jan 23, 2014 | 08:32 PM
jalodge's Avatar
I am having a similar problem with the clunking noise when the body rolls but it seems to be coming from the back, not the front.
Old Jan 23, 2014 | 08:54 PM
johnnyjohnny's Avatar
Check your watts linkage bushings. Mine are shot and makes the clunking in the rear when the body rolls (especially when backing up).
Old Jun 25, 2014 | 11:23 AM
Rdhilaire's Avatar
Hi DM.
I read your posts alot.
I just got back from the dealer because my fluid was leaking. He said it would be $1,000's to fix generally, and just disable it, turn it off and put the new belt in.
I noticed right away the difference in the handling. Softer, more roll in curves. I feel like I just ruined my precious Rover. He said it was in AWESOME shape, no frame rust at all, Very solid. I want to keep it forever. (being unempoyed partially doesn't help with maintenance) What are your thoughts?
Old Jun 25, 2014 | 12:04 PM
acamato's Avatar
Originally Posted by Rdhilaire
Hi DM.
You may want to start a new thread, since your issue is different from the OP. You may get a better response.
What is leaking? Do you have tools? You may be able to fix it yourself for a lots less $$.
Old Jun 25, 2014 | 12:11 PM
dusty1's Avatar
on topic.just read through this.
I had a slight clunk, at low speeds (ace dormant speeds) traced it to the front bushings that cradle the roll bar to chassis. replaced and church mouse.
Old Jun 25, 2014 | 12:17 PM
drowssap's Avatar
new more information ? whats leaking? the pump, the lines, the hoses, the rams?
Old Jun 25, 2014 | 12:56 PM
Richard Moss's Avatar
The ACE actuator on the front of mine had a huge leak - I changed the actuator but obviously had air trapped in there because it would throw up the warning whilst driving.
I had the car up on axle stands for a while whilst changing the brake pads and after that it was fine - it must have self-bled whilst the suspension was dangling down.
Result
As an aside, I was sceptical about whether ACE was any good but having driven it with and without I have to say that it makes a HUUUUUUGE difference on the road.
Tin_Man
Apr 12, 2014 11:12 AM
Chmielarczyk
Nov 3, 2012 03:15 PM
tbuckt007
Apr 13, 2010 11:46 AM
jtm964
Freelander
Sep 20, 2008 03:01 AM
Disco_one
Aug 21, 2008 05:46 PM
