Need Driveshaft Help...
Old Mar 9, 2009 | 10:43 AM
indasevens's Avatar
Default Need Driveshaft Help...
...I need the "carrier" part of the driveshaft. Front of a 2003 Discovery. Wifes truck and she called me with big "clunking noice" so i got under and took out the driveshaft--I can rebuild it but it messed up the whatever center pivot piece. Any suggestions where I can get one ASAP!!! Thanks
Old Mar 9, 2009 | 10:48 AM
A Percision 617 Centering ball kit.
Old Mar 9, 2009 | 12:19 PM
khuds308's Avatar
This happend to the previous owner of my 96 disco I. I got the disco back to the house with a flatbed and called Great Basin and got a entire new drive shaft assembly. it's supposed to be stronger. I have not put over 10k miles on it yet but so far it's holding up good. Maybe this is an option for you.
Old Mar 9, 2009 | 12:50 PM
indasevens's Avatar
Default where...
Where do i get one??? The local dealer said they only sell the entire shaft unit. Thanks again for all the help.
Old Mar 9, 2009 | 01:11 PM
okdiscoguy's Avatar
he meant precision 617. Most regular auto parts stores will carry it. You can also pull the shaft and have a driveline shop do it all for you. Make sure and go back with the greasable u-joints and have it balanced...
Old Mar 9, 2009 | 02:19 PM
indasevens's Avatar
Default i can get the u-joints....
....with no problem. The problem is the unit in which hold the u-joints and the center "bearing" It damaged it and need to find new one.
Old Mar 9, 2009 | 02:31 PM
salve7's Avatar
I would call up Tom Woods and have them fab one for you. It would probably be quicker and would cost around $350.
robert.juric
Nov 3, 2022 06:08 PM
acg
Jul 7, 2013 07:26 PM
discomedic4
Apr 26, 2010 08:41 AM
NW_rockhound
Jul 30, 2008 08:13 AM
