Need to finish this fight
Hey guys, got my misfire sorted out finally found time.. Unfortunately sitting battery died so need to pickup a new one.
List of things I need to finish, before I think of taking it for safety (oshawa ontario, I am the new owner)I would appreciate any advice if anyone has had these issues it's my first 4x4 I pretty much exclusively worked on dinky FWD cars.
1). Pinion seal is leaking on the front differential, what are these flange kits on Atlantic British is one worth doing with my seal?
2) I have a 4.0L V8 2000, I can't shift the transfer case I am assuming the linkage is seized up since it was old man driven prior to me buying it (stuck in high) how hard would putting parts from a D1 or a 2004 model year be to rectify the issues if I'm pulling the center console apart I might as well upgrade
3) transmission is leaking, looks like the pan.. previous owner did the service but put RTV under the gasket. Suspect gasket is sitting wrong. I've bought a new gasket how much fluid is in there, my local Canada Tire said 20 liters (wtf??)
Richard Gallant (12-10-2020)
yloDiscoII
02-10-2010 10:03 PM
