need help !!! got a question???
Old Aug 2, 2008 | 06:35 PM
djmik2000's Avatar
4th Gear
Default need help !!! got a question???
Sorry to bother you guys but i need your help.
My wife got into a accident with our rover discovery II 2001 and long story short some bumper and grill damage after the impact.I noticed a noise squeaking took it to a local mechanic and he explained that serpinebelt got loose because the water pumps pulley is not functioning correctly or damaged,I don't remember his exact words. Basically water pump and belt must be replaced.
my question is if i'm going to replace water pump,belt,& probably hoses should i consider replacing the timing belt or chain?????? please your expertise would be a great help....
thank you: Mike V
Old Aug 2, 2008 | 07:23 PM
Default RE: need help !!! got a question???
There is no timing belt on a gas engined LR. The timing chain will last the life of the engine.
This would be a good time to also replace your belt tensioner.
Old Aug 2, 2008 | 07:25 PM
Make sure that they also flush the cooling system and that they use the same kind of coolant that is already in there. If its green stay green, if its pink stay pink.
Old Aug 2, 2008 | 10:01 PM
okdiscoguy's Avatar
On the coolant, Dexcool only on a D2.
Old Aug 3, 2008 | 07:21 AM
djmik2000's Avatar
4th Gear
Thank you so much for your help & suggestions.
glassman66
Jul 7, 2012 03:10 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
Disco2Fever
Oct 19, 2008 08:05 PM
ChadBlackHSE
Oct 4, 2007 04:58 PM
