Need help identifying these 4 items please..
Old May 27, 2012 | 08:38 PM
Keecho's Avatar
Default Need help identifying these 4 items please..
2003 disco 4.6 coming back together.
1. photo 1 is a plastic hose coming from back of engine sorta long but, unknown where is goes.
2. photo 2 is a loose wire couldnt figure out what is connected to but i then realized that i only had 1 knock sensor. and missing one on drivers side so I ordered it. assuming this wire goes there? if so, where do i bolt the ground to?
3. photo 3 is another plastic hose but its clipped itno a clip on the firewall was disconnected, does it even connect to anything?
4. photo 4 & 5 is im hoping my missing plug for my camshaft sensor. dont know how that wire got cut but I ordered a plug and will be soldering wires to make a plug for the camshaft sensor. can anyone tell me which wire goes where? its a 3 prong connecter standing in front of car which colors in order from closest to farthest from you? if anyone can tell me this I owe you one
thanks a bunch guys.
Attached Thumbnails Need help identifying these 4 items please..-photo-1.jpg   Need help identifying these 4 items please..-photo-2.jpg   Need help identifying these 4 items please..-photo-3.jpg   Need help identifying these 4 items please..-photo-4.jpg   Need help identifying these 4 items please..-photo-5.jpg
Old May 27, 2012 | 09:17 PM
Black plastic hoses - usually vent lines from axle and transfer case
See pix of connectors you searched for. Ground lug can go anywhere that is a metal frame point. Wire colors in the CMP plug are black (1), slate with blue (2), and brown with pink(3).
File Type: pdf
File Type: pdf
Old May 28, 2012 | 01:04 AM
Keecho's Avatar
Hey buzz thx for the diagrams, those are perfect.
As far as the. black hose, all the vents end up by the firewall, this one is a little long. Not sure if it is but could be i guess. So just U turn it and just stick it back down the firewall?
Thx again.
Old May 28, 2012 | 08:12 AM
i forgot to mention vent from auto transmission.
Old May 28, 2012 | 09:51 AM
tee51397's Avatar
On the first one, are all the expansion tank and throttle body heater lines accounted for?. The other looks like the axle breather. Cant really tell from the other wire pics
Old May 30, 2012 | 01:34 AM
Keecho's Avatar
On the intake there is one that just plugged in there on the very top passenger side, what and where is the expantion tank?
Old May 30, 2012 | 04:00 AM
Expansion tank is the coolant reserve jug. Do you have coolant coming out the mystery line? See attached from RAVE for coolant flow path.
File Type: pdf
Old May 31, 2012 | 10:22 AM
Keecho's Avatar
No, there is no coolent coming out of mystery line. But offnote, was sort of weird to me but why is there coolant going to throttle body anyways? I have a line going from expansion tank to throttle body. Its hooked up and working but never seemed like a good idea to me?
Unless its for like a insulator to cool off throttle body?
There is no vacumm or water coming out of mytery line.
Old May 31, 2012 | 10:32 AM
drowssap's Avatar
it is to keep the throttle body from freezing in the open position, in the winter.
0 degreee air and 70 mile and hour wind leads to some pretty low intake air tempertures
Old Sep 24, 2013 | 10:33 PM
redmanxi's Avatar
Is there a part number on the bolt for the drivers side knock sensor? Or even a size I can grab at home depot?
