Need HELP! Intermittent crank no start
Old 05-08-2012, 08:53 PM
rockyblue123's Avatar
Default Need HELP! Intermittent crank no start
Hello
I have a 2004 Discovery 2s. Drove into driveway a few days ago and car stalled. Cranked over but would not start. I checked the fuel pump relay,relay OK. I put starter fluid in intake and vehicle tried to start. So, I figured bad fuel pump. Next morning, started right up, but stalls out after about 20 minutes.
I replaced fuel pump $325.00 still same problem, after about 20 minutes dies and wont start. Let sit overnight, runs for awhile then dies again. No fuel filter to service from what I heard.
Any suggestions?
Old 05-08-2012, 09:03 PM
You need a new crank position sensor.
$70 part, should have asked first.
Looking at the engine, 3o'clock position on the bell housing.
You can buy it at AutoZone, exact same part just in a different box.
http://www.roverparts.com/Parts/ERR7354G.cfm
Old 05-08-2012, 09:08 PM
Is it easy to replace? Thank you so much!
Old 05-08-2012, 09:09 PM
Easy to replace? Kinda no, kinda yes.
2 10?mm bolts hold it on, take note of the spacers as they MUST go back in the same order they came off.
If you have large hands it is hard to replace, small hands not to bad.
There is a write up in one of the sticky's on the top of the DII page.
Old 05-08-2012, 09:11 PM
That was my next move, but, thanks for confirming. Will repost tomorrow after I replace it to let everyone know if it worked. Thanks again!
Old 05-08-2012, 09:12 PM
Good luck, hope it all works out.
Old 05-08-2012, 09:17 PM
Here's a page on it, like the man says, every little spacer goes back just like it came off. Easier to do if you plug in first and let it dangle.
File Type: pdf
Old 05-08-2012, 09:40 PM
Psichotic's Avatar
I can recommend a mechanic that can do it for 937.00 and a few weeks...
Old 05-08-2012, 09:50 PM
DonRW2007's Avatar
Default Had this done on a road trip...
My CPS failed on the way to the beach, and the mechanics at a Goodyear dealership hooked me up for about $150 parts and labor (as I recall) and I was back on the road in 2 hours. Probably would have taken me 3 hours at home, with my luck and mechanical prowess... CPS is a good preventive maintenance item in my book.
DRW
Old 05-09-2012, 04:47 AM
re:
Quick Reply: Need HELP! Intermittent crank no start
