need help with my new 99 Disco I
I just bought my first Land Rover and noticed a few problems with it when I got it home.
1- play in the steering wheel. I noticed this on several older Discos as I was shopping. Is there an easy fix.
2- It tends to run hot when idleing for a while. I had a jeep wrangler that did this and after replacing the thermostat and the water pump, I found it was the fan clutch. Any advice so I'm not replacing the entire cooling system?
3- its a slow starter. I have to hold the key for a few seconds to get it to turn over... normal or needs work????
I'm not afraid to get my hands dirty, but with parts being more expensive than I'm used to, I don't want to rebuild everything trying to fix something. I'm just not super familiar to what's normal and what's not on the Disco.
Other than that, I love it! I've dreamed of having one for years. My wife and I argue over who gets to drive it every morning.
on
RE: need help with my new 99 Disco I
I would grab a buddy and have him turn the steering wheel while your underneath it checkingfor play.
Running hot at idle would suggest a bad fan clutch.You should be able to rotate it by hand fairly easily. Feel to see it has roughness upon rotating it and check for excessive up down play. How many miles are on it? Replacing the thermostat is a cheap and easy fix, that can provide additional peace of mind even if that's not the cause.
Slow starting could just be do to dirty plugs and carbon build up in the injection system. I'd get a bottle of seafoam and dump it in the gas tank. You'll want to do this anyway so start there and we'll see how it goes.
1. I had the samething it was the arm coming off the power steering pump,
I had a wheel alinement and that arm relpaced at a Land Rover Dealer for $175.
2. the fan clutch maybe it, they will go out , I would change the thermostat also.
3. Maybe a starter needing a rebuild , check the CCA on the battery first.
if I understood the (slow starter).
ORIGINAL: mdoty
whurst79
01-28-2013 09:24 PM
striversrowatl
05-01-2010 11:20 AM
NightWithTheDisco
Audio/Visual Electronics
12-02-2005 03:20 PM
