Need Help - Nanocom Key Fob Programming - Key Not Detected
Hey All
I finally got a set of 315mhz key fobs and rented the Nanocom from @Brandon318 . I am following this video tutorial.
Everything seems to be going fine until I do the last step (key detect). The new key is not detected. A couple of other details:
- I have verified the nanocom receives a transmit from the new key
- My old key fob is detected just fine.
- It doesn't seem to matter which key programming slot I use - none are detected in the final step.
Also, sometimes it took cycling through the key programming procedure one or two times. Some keys synced up right away, others took 2-3 times. No idea why the difference. Could be battery levels.
That could very well be, lots of people are running into that issue. I tried to program some with my Nanocom when I was up at Austin Roverworks as their T4 wouldn't do anything. Well they were a pair of those Mini Cooper remotes, and in the end they were the wrong MHz. Then a customer had an OEM key and the T4 didn't make it work. I grabbed the Nanocom and had it programmed in just a few seconds. I've programmed a few of the aftermarket units below with no issues.
315MHz Key Fob
315MHz Key Fob
315MHz Key Fob
315MHz Key Fob
doc
