Need Help newbie question
Old Apr 10, 2011 | 08:23 AM
jaydog101's Avatar
Default Need Help newbie question
this may be a real stupid Question but I have and oil leak that I can not see because of a fiberglass cover under the engine, It is the one with the hole to change the oil filter on it.
Is there an easy way to get it off???
I removed all the bolts but found no easy way to shimmy it out.
thanks in advance
I have an 04
Old Apr 10, 2011 | 08:32 AM
Bundu's Avatar
Banned
Sawzall.... that cover is worthless and just gets in the way.
Old Apr 10, 2011 | 09:42 AM
buick215's Avatar
I don't know but I wouldn't sawzall anything on my truck even though I have felt like doing it on more than one occasion . If you move it around you should be able to remove it. I know that I have removed mine twice, good luck.
Old Apr 10, 2011 | 12:56 PM
thospb's Avatar
Try to rotate the cover 90deg counter-clockwise and it will come out under the drivers seat area.
Old Apr 10, 2011 | 06:58 PM
grandkodiak's Avatar
someone might have put it in backwards... mine was! its just a few screws along its length and it comes right off. there are 1 or 2 screws on the sides that you might have missed. its also flexible too though, so just squish it abit and yank it out from the bottom, just be carefull of the oil filter.
Old Apr 10, 2011 | 09:50 PM
jaydog101's Avatar
thanks guys I will give the rotation thing a try and report back,
allwood2006
Jan 28, 2012 08:42 PM
4wheelinbum
Jan 24, 2010 09:51 AM
vnranger
Apr 26, 2009 11:18 PM
discolucy
Apr 17, 2009 10:08 AM
jmrmode
May 9, 2008 11:27 PM
