Need help please?
Old Jul 23, 2019 | 10:34 AM
Mike53's Avatar
Default Need help please?
I have a disco 2 2001 with the boush injection I have to change out my head gaskets but can’t go any further I am at then Point where you disconnect the fuel injectors I mean not fully I just want to know how you release them the tab has on each side a green little tab I have pushed and pulled I have done everything I know but nothing works does any one know what I am going through am I not doing it right?Is there a trick to it?please anyone i am in a real bind the Land Rover is down in a friends drive way that moved just my luck!
Old Jul 23, 2019 | 11:31 AM
Red5's Avatar
Trying to remember, I think they have the little metal wire on the connector. Push it in (toward the injector) with a flat screwdriver and they come right off.
Old Jul 23, 2019 | 11:51 AM
The Deputy's Avatar
Yep, on the longer edge of the injector plug, push the wire towards the plug housing and pull gently. Do not remove wire clip itself, not necessary.
Brian.
Old Jul 23, 2019 | 04:01 PM
Mike53's Avatar
Default A big help!
Thank you for the tip !They are off now thanks a million!!!!’
britguy
LR2
Sep 21, 2019 07:12 PM
bjordan
May 27, 2019 04:58 AM
timxxv
Dec 22, 2014 05:28 PM
RicketyTick
Jun 6, 2014 04:23 PM
Willie00d2
Feb 28, 2010 08:11 AM
