Fuel Injector Tip
Old May 22, 2019 | 09:28 AM
bjordan's Avatar
Default Fuel Injector Tip
Hi Folks.
My mechanic friend started taking the engine on my 2002 Discovery II apart yesterday to replace the blown head gasket. During the tear down, he notices the fuel injector tips need to be replaced. He described them as either being red or brown in color and shaped like a derby. I looked and found the O ring seal kits we need, but not the injector tips. Any thoughts? Do I need to buy new injectors, or can anyone point me to what he is describing?
Thanks for the help!
Old May 22, 2019 | 09:38 AM
User's Avatar
You don't need them. I take them off each time I rebuild my injectors.
Old May 22, 2019 | 09:53 AM
bjordan's Avatar
As in, you them throw away? As I understand the text from my mechanic, this is the end of the injector that goes in to the intake that has the tip we are looking for (that you throw away), not the end of the fuel rail. Just to be clear.
Thank you!
Old May 22, 2019 | 10:40 AM
User's Avatar
Yes, the part that basically holds the o ring on and looks like a c-clip. Not what holds the injector on to the rail.
I throw them away, they break while replacing o rings and are used for keeping them on and something with fuel flow. As others have mentioned here they aren't needed with these engines and can be discarded.
All of my trucks that I've head the top end apart I have them thrown away. Or if I replace injector o rings I'll toss them.
Old May 22, 2019 | 11:28 AM
Lisa Bunch's Avatar
Some of mine broke, they didn't appear to be all that functional since there is no where for that o-ring to go. Clean/test and reassemble with new o-rings.
Old May 22, 2019 | 11:34 AM
bjordan's Avatar
Roger. Thanks to both replies - I spoke to my mechanic and we are moving forward with throwing the tips away, but replacing the O rings with new O rings.
Thanks as always!
Old May 27, 2019 | 01:52 AM
Llamasayswhat's Avatar
They are called pintle caps, youre best off just buying a rebuilt set of injectors from eBay for $80 and tossing them in. At that price it isnt worth even thinking about
Old May 27, 2019 | 04:58 AM
shanechevelle's Avatar
This is solid advice.
If it was simple I wouldn't care, but ripping all that sh#t off isnt worth it. Buy those rebuilts off of Ebay, I have a set in my rover now.
04in719
Jul 14, 2017 12:23 PM
humroot
Nov 30, 2014 12:09 PM
tylor36
May 22, 2013 12:31 PM
davidlafrance
Apr 27, 2011 05:08 PM
Willie00d2
Feb 28, 2010 08:11 AM
