Fuel Injector Removal
Old Feb 27, 2010 | 04:50 PM
Willie00d2's Avatar
Default Fuel Injector Removal
I am replacing all the o-rings on my injectors. Is there a trick to get the injectors out of the fuel rail? It seems to be the o-ring holding it in there.
Thank you,
Willie
2000 Discovery II
V8
Old Feb 27, 2010 | 04:52 PM
Rovin4life's Avatar
why are you replacing the orings? They don't need replacing at all.
Old Feb 27, 2010 | 04:53 PM
antichrist's Avatar
They just get sort of bound in with age. Just really have to pull.
Be prepared to need a new fuel rail. When I did the one's on my Disco the cups in the rail had corroded and I couldn't get a good seal with new o-rings. Petrol spewing all over the engine isn't a good feeling.
If they aren't leaking, I'd leave well enough alone.
Old Feb 27, 2010 | 10:28 PM
Willie00d2's Avatar
The service manual said to change the o-rings when removing the injectors. The head gasket kit I bought came with 16 injector o-rings. It was not leaking so I will leave them in the fuel rail and just change the manifold side. I wonder what land rover would want for a new fuel rail? Probably more then my rover is worth.
Willie
Old Feb 28, 2010 | 06:10 AM
antichrist's Avatar
I got mine on sale for $89 and TNLR. I think the regular price is around $120 or something.
Old Feb 28, 2010 | 08:11 AM
lipadj46's Avatar
The head gasket kits come with a bunch of odds and ends that you would only use if you were completely rebuilding the top end. I would not replace your FI o'rings unless they are leaking.
dollachikin
Jul 15, 2009 08:35 PM
tornado_735
Mar 31, 2009 09:33 PM
lennie5936
May 16, 2008 06:31 PM
lennie5936
May 7, 2008 11:45 AM
DeepBlueWater
Oct 15, 2007 07:38 PM
