Need help removing steering knucle
Beating on the red arrow does cause the tapered joint to pop out but when I don't have the patience for that I and I am replacing the ball joints I just cut the ball joint stem with a grinder blade attached to a drill. It takes about 15-20 mins. After that it takes about 3 or 4 taps to pop the stem out of the knuckle. Pressing the ball joints out without the ball joint stem in the way is easier too.
I took the top off with a 9in grinder, then profiled ground the top with a small grinder nice a smooth in line with the housing, then I got my stick welder and ran round the centre of the ball joint an got it nice and hot, careful not to weld on the axle housing, let it cool down then 2 taps with a hammer it dropped out
