need help rite now
Old Aug 23, 2009 | 10:41 PM
JumPeR04's Avatar
Default need help rite now
I got a 99 discovery 1 wit emergency lite on and they won't go off. Had to pull the neg on the battery
Old Aug 23, 2009 | 10:59 PM
JumPeR04's Avatar
It is the alarm system and how do you disable it because my key won't work
Old Aug 23, 2009 | 11:03 PM
NiteTrain's Avatar
what do you mean emergency light? your flashers?
Old Aug 23, 2009 | 11:20 PM
JumPeR04's Avatar
Yea that what I mean
Old Aug 24, 2009 | 01:09 AM
NiteTrain's Avatar
are they flashing or on all the time? pull the fuse.
Old Aug 24, 2009 | 05:13 AM
hilltoppersx's Avatar
your key fob doesn't work and you're trying to disable the alarm? stick the key in the driver side door and turn it.
Old Aug 24, 2009 | 07:40 AM
You can't disable the alarm, if you do the engine will not start again.
Try using the key or FOB and lock and unlock the door 3 times, see if that resets the alarm for you.
steveo2000
Oct 30, 2024 08:31 AM
uoflcardfan77
Aug 6, 2015 03:47 PM
bcolins
Feb 20, 2014 11:30 PM
handsome rob
Feb 15, 2009 11:54 PM
Finn Dunn
Aug 10, 2008 06:23 PM
