Need Help - (sick 95 disco) - Colorado
Old Feb 4, 2010 | 09:12 AM
mattrickman's Avatar
Will replace the cap and rotor and report back...
Is there a way to test the distributor?
Thanks
Old Feb 4, 2010 | 10:19 AM
okdiscoguy's Avatar
be careful when removing the rotor, I can't remember what it does, but something springs out if you force it...
Old Feb 13, 2010 | 02:45 PM
replaced the Cap and Rotor this morning and it didn't make a difference.
If the distributor was bad, timing should be off correct?
So I have fuel pressure, timing is correct. new cap and rotor now... Is this cam or valve issue?
Anything else I should try prior to towing it to a Rover Shop?
Old Feb 13, 2010 | 07:08 PM
AK Rover's Avatar
Take the truck down to JC's and have Jeff and his crew check it out. They'll get it figured out a lot quicker and probably cheaper than random guessing will. I had JC's do a lot of work on my Rover and I highly recommend them.
Old Feb 18, 2010 | 12:09 PM
Well I took the truck down to JC's and one of the exhaust lobes on the cam was pretty much gone. They are going to replace the cam, timing chain/gears, lifters and I am also having them replace the Head Gaskets while they have it torn apart. $3600 later, hopefully my truck will be back to normal. ugh
Old Feb 18, 2010 | 01:30 PM
okdiscoguy's Avatar
dang.. ask them about putting a 4.6 cam in there while they have it apart. It will increase ari flow and give a little more torque.
Old Feb 18, 2010 | 02:14 PM
They said that they were going to put a performance cam in, I will find out exactly what that means.
wrongway1
Jan 8, 2014 03:12 PM
Mark G
Dec 25, 2010 09:32 AM
indasevens
Jul 3, 2009 09:59 PM
indasevens
May 25, 2009 11:20 AM
kinsella
Apr 21, 2007 10:21 AM
