Need help w '04 HK subs
Trying to find replacement sub woofer speakers for a 2004 D2 Harmon Kardon system. Been searching all over with no luck!
Got a complete sub woofer assy P/N XQA000010A / Phillips - speakers barely move.
Got a replacement set of 6.5" Pyramid 300W / 4 Ohm - move even less than the Phillips.
Swapped out the amp with a known good one - same results.
I have the feeling I have the wrong type of speakers in both cases above.
Does ANYBODY know what type of replacement speaker (Wattage / Ohms) I need?
Thanks in advance.
Thanks in advance.
Here’s the rub - I never knew if the subs ever worked. Noticed they were not making any noise about a year ago. Only speakers I’ve ever seen in the tailgate are Phillips. Head unit with factory nav., HK amp, HK speakers (A pillars and doors), CD changer, mystery sub woofer.
