Need help w '04 HK subs
Old May 6, 2020 | 04:43 PM
Tony Luna's Avatar
Default Need help w '04 HK subs
Trying to find replacement sub woofer speakers for a 2004 D2 Harmon Kardon system. Been searching all over with no luck!
Got a complete sub woofer assy P/N XQA000010A / Phillips - speakers barely move.
Got a replacement set of 6.5" Pyramid 300W / 4 Ohm - move even less than the Phillips.
Swapped out the amp with a known good one - same results.
I have the feeling I have the wrong type of speakers in both cases above.
Does ANYBODY know what type of replacement speaker (Wattage / Ohms) I need?
Thanks in advance.
Old May 6, 2020 | 06:13 PM
DCDisco2's Avatar
Stock head unit?
Old May 6, 2020 | 07:41 PM
Extinct's Avatar
Why not repair the original ones? The HK's are actually pretty good - polymer cones,large magnets. Normally only issue is the surrounds, you can get replacement surrounds.
Old May 6, 2020 | 10:20 PM
Tony Luna's Avatar
Originally Posted by DCDisco2
Stock head unit?
Yes. The entire system is stock. Head unit (with factory nav), amp, CD changer, and speakers.
Old May 6, 2020 | 10:26 PM
Tony Luna's Avatar
Here’s the rub - I never knew if the subs ever worked. Noticed they were not making any noise about a year ago. Only speakers I’ve ever seen in the tailgate are Phillips. Head unit with factory nav., HK amp, HK speakers (A pillars and doors), CD changer, mystery sub woofer.
ToiletDuck
Oct 13, 2019 08:28 PM
msggunny
Audio/Visual Electronics
Sep 26, 2012 09:53 AM
Classklown90
Jan 17, 2010 09:57 PM
Robwsup
Jan 16, 2010 10:59 PM
oljohnboy
Sep 23, 2009 11:05 AM
