Need help w/ Check engine codes; Hopefully this morning before it gets too hot.
Old Aug 31, 2008 | 01:33 PM
bcolins's Avatar
Default RE: Need help w/ Check engine codes; Hopefully this morning before it gets too hot.
Yes, I do have a slight exhaust leak on cold start up. Funny you mention that,...I was just eyeing the manifold bolts about an hour ago wondering if I could tighten them a bit without risk of cracking or breaking anything.
Why do you ask about the leak.........can that throw the lean code?
Brian
Old Aug 31, 2008 | 01:46 PM
No you cannot tighten the bolts, it is a crack in the exhaust manifold itself. VERY common on LR's, once the manifold heats up and expands then the crack goes away. A muffler shop can weld it, other than a new manifold that is the only other fix. And no it will not thow a code because of the leak. Unless it is REALLY bad.
Old Aug 31, 2008 | 07:51 PM
roverguy7's Avatar
if its only a small leak, i doubt its your problem, but yeah, a exhaust leak will suck air into where it leaks out inbetween exhaust strokes, when it does, itll trick the o2 sensor into thinking its running lean.... anyway, you need to find out if you have a vac leak, generally a mafs will throw both banks, since all the air goes through it for the whole engine. could just be a o2 sensor, check your air filter cover, make sure its on correct, not bent in on the back lh side at the filter (looking at it)
Pik
Mar 27, 2013 08:00 PM
br0keit
Jul 14, 2012 05:50 PM
94svt50
Jul 8, 2012 03:31 PM
LRScott
13
Apr 7, 2010 02:26 AM
patrick in pa
Jul 13, 2009 11:50 PM
