Need help w T Stat install
Old Feb 23, 2013 | 11:41 AM
Pik's Avatar
Pik
Default Need help w T Stat install
This morning I replaced the original 195 T Stat with a land rover 185 T Stat.
Put all back together warmed it up with reservoir cap off. Bled it a couple of times, then tightened everything up.
Problem is temperatures are spiking to 217/220 while I am in the driveway trying to finish bleeding. Am afraid to drive it on road in case it way overheats.
Did I miss something while refilling or is it likely the T Stat is bad?
Andy
Old Feb 23, 2013 | 12:11 PM
Rover_Hokie's Avatar
Make sure you have the hoses on correctly connected to the two top hose connections on the t-stat. Do you have the RAVE workshop manual to refer to?
Old Feb 23, 2013 | 12:19 PM
Pik's Avatar
Pik
I have the manual, the hoses are on correctly.
I have it elevated on ramps now in an effort to help get the air out...
I think it is either air-bound or the T Stat is non-functioning...
Any advice on how to prime it better if it is an air pocket?
Old Feb 23, 2013 | 12:34 PM
bballjames's Avatar
Did you test the t-stat before you put it in? If you think you got all the air out, then I would take the t-stat out and put it in a pot of boiling water to make sure that it is fully opening.
Sometimes when there is air in the system, you can hear a gurggling behind the passenger side dash. What bleed procedure are you using?
Old Feb 23, 2013 | 12:48 PM
Pik's Avatar
Pik
I am making progress, I elevated the Rover on front ramps.
Got good heat in cabin, no gurgling sound from dash.
Feel confident for a short road trip. My used electric fan kicked on at 212 just now.
First that's run under my ownership.
Old Feb 23, 2013 | 12:59 PM
jfall's Avatar
new tstat may not help at all
i just did the rad
fan clutch
waiting for mt 180 degree tstat
engine gets too hot for cooling system design
Old Feb 23, 2013 | 02:17 PM
Pik's Avatar
Pik
Test drive okay, no more temp excursions. Saw from 190 to 200 for most part, need to bleed a little more air.
Old Feb 23, 2013 | 10:09 PM
The stat design precludes an air pocket, it has holes and cavity ports, etc. Here's the plumbing chart.
Attached Thumbnails Need help w T Stat install-d2-coolant-flow-001.jpg   Need help w T Stat install-land%252520rover%252520thermostat%252520005.jpg   Need help w T Stat install-d2-stat-internal.jpg
Old Feb 23, 2013 | 10:16 PM
Pik's Avatar
Pik
Perhaps I was overly cautious... Just got back from a drive, never got over 197. Quite pleased.
Old Feb 24, 2013 | 11:36 AM
That is pretty much what I see now as well. 194 on the highway, and 197-200 around town.
