Need paint in larger quantity than just a paint stick...
Old Aug 18, 2020 | 07:57 PM
Brandon318's Avatar
Default Need paint in larger quantity than just a paint stick...
Found a nice bit of rust all along the door seal area today. Ground back to good metal, treated, primered... but now debating whether to paint with just black rustoleum since it's out of sight, or do it right and order a pint or quart of Giverny Green. So far the places I've found online (searched for only a minute or two) are about $100/quart. You fellas have any other ideas or sources that might be a bit more reasonable? Or just an opinion on how to paint this area in general? Any close matches in Home Depot's selection?
Old Aug 18, 2020 | 08:01 PM
Richard Gallant's Avatar
Try your local paint store see if they can color match, you might have to find something you can pull off. Unless they have portable unit
Old Aug 18, 2020 | 09:01 PM
Red5's Avatar
I had some rust in the same places. Door sills, fuel pump access, etc. Since it’s all covered by carpet anyhow, I just used rattle-can Rust-oleum silver and called it good. Matches well enough to my original Zambezi and only a few bucks.
Old Aug 18, 2020 | 09:11 PM
some places can do a paint matched rattle can
Old Aug 18, 2020 | 10:15 PM
acg's Avatar
acg
I don't think you need a whole pint or quart to paint the one door sill. Just get inexpensive generic primer from Home Depot. Then buy a rattle can of customized paint (see attached) for about $26.95.
File Type: pdf
Old Aug 19, 2020 | 10:48 AM
WaltNYC's Avatar
I've purchased a rattle can from paintscratch.com and have been very happy with the match. About $27 for one can.
Old Aug 24, 2020 | 09:30 AM
777AIA's Avatar
I have had good luck with the rattle can option at touchupdirect.com
Don’t forget to get two step paint process.
Paint and gloss coat.
Old Aug 24, 2020 | 06:39 PM
stillruns's Avatar
Second paintscratch.com. Worked well on another car.
Old Aug 25, 2020 | 09:14 AM
nashvegas's Avatar
Paintscratch is your best bet (or one of their online competitors).
Just make sure you prime it first if it's bare metal, and don't do what I once did... get the primer from the same source and make sure they are compatible.
I applaud your attention to detail !
spannermonkey
Feb 4, 2020 06:40 AM
turf63
Jun 23, 2010 04:13 AM
Spencerfitch
May 12, 2010 11:54 AM
markroll
Mar 12, 2008 09:36 PM
DuplinDisco
Feb 10, 2008 12:32 PM
