need quick info..d2 prop shaft orientation n torque spec
Old Mar 29, 2011 | 10:41 AM
grandkodiak's Avatar
Default need quick info..d2 prop shaft orientation n torque spec
myfront shaft and bolts came in at work but i forgot to look at rave. can someone tell me which way it faces under car and the torque specs for the 8 bolts?
ps theres no special alignment right? it came prebuilt and pregreased
Old Mar 29, 2011 | 11:13 AM
thospb's Avatar
The Double-Cardon joint goes to the rear (closest to Trans). The bolts are torqued to 35ft/lbs. Make sure you use new nylock nuts, available at mot hardware stores.
Old Mar 29, 2011 | 11:31 AM
Bundu's Avatar
Banned
There is only one way it can go on front to back, the bolt hole spacing is different - double cardan to the back. Note that on the front flange the bolt holes are equally spaced, or the rear flange they are not.
Old Mar 29, 2011 | 12:26 PM
hilltoppersx's Avatar
you should re-grease the centering ball before putting it on.
Old Mar 29, 2011 | 03:00 PM
shes all in... thanks for the info guys.
man what a pain in the ***, they couldnt make the damn things a half inch wider so you can actually use a torque wrench without hammering on a ujoint adapter and thin walled socket first! 3 minute affair was 20 minutes just because of that. lameness!
Old Mar 29, 2011 | 03:04 PM
Bundu's Avatar
Banned
I don't bother with sockets and a torque wrench, just tighten them as far as you can with a 3/8" socket and a flat wrench. It's not a head you are torquing, as long as you do not strip the bolts or nuts you are fine.
chicane
Oct 24, 2014 01:03 PM
utah95
Feb 20, 2014 11:33 PM
wastedincome
Oct 24, 2012 03:10 PM
boris_gti
Oct 6, 2011 11:10 PM
snorlax
Apr 7, 2008 02:16 PM
