Need some help with a $100 D2 I picked up
Old Dec 27, 2020 | 12:02 AM
Richard Gallant's Avatar
@BS50MGSXR The cable is unlikely to have gone bad more likely it is dry and/or not adjusted correctly
Hit the springs on the side of the throttle body with a good lube, as well as the cables and check the cable tension. But it you look a the image below, you need to lube the bare cable and then press your pedal up and down a few times to get things moving freely.
You can also manually active the throttle to make sure it is springing back correctly. If it seems to be binding remove the cables, and see if it works correctly without them. If it does replace them one at time to see which one is binding. Then lubricate liberally and work the cable it should free up.
If you still want to replace it I can send you a used one for 5.00 plus shipping.
Check page 376 or 19.20.05 in the RAVE for adjustment info.
Old Dec 27, 2020 | 03:51 AM
The Deputy's Avatar
Yes, most likely on the throttle body end of things. Pop ofc the intake tube and clean butterfly in housing and lube spring assembly. Probably save you from changing throttle cable.
Old Jul 21, 2021 | 06:46 PM
BS50MGSXR's Avatar
Its been a while sins getting on here and checking the thread, I did get all the head lights working, was just one bad bulb and the driver side was a dirty connection. Got two new bulbs and kept the one working bulb as a spare. One of the PIAA lights are working as well but still need to look into that as well. Wish I had checked this earlier, as I did end up buying a used throttle cable on Ebay a week or so ago. The sticky throttle seems to be the spring return on the peddle I noticed recently. So I still need to pull the cable from one of the ends and test the peddle throw. After this, I still need to chase down the leak in the roof and check into the 3 amigo lights. How tricky is pulling the throttle cable from the peddle side?
04in719
Jul 3, 2017 10:29 AM
SensiRider
May 18, 2017 04:39 PM
Discoaddictnorth
Nov 21, 2015 11:34 AM
jimvw57
Mar 8, 2014 09:17 PM
trp34
May 18, 2012 07:49 AM
