Needs new BCU
Old Jan 2, 2018 | 10:57 AM
CollieRover's Avatar
Default Needs new BCU
The shop diagnosed my start problem. It is the BCU being tempermental.
I will source a good used BCU, but does anyone know if I can program it with an autocom or will I need to take it to the dealer?
Old Jan 3, 2018 | 07:38 AM
I am getting a BCU from Paul Grant, and in the RAVE Manual it says that communications between the IDM and BCU can be set up after replacement by leaving the ignition on for 5 minutes in the description portion. IN the repair directions it says to use Testbook. So we will see.
Old Jan 3, 2018 | 07:57 AM
abran's Avatar
Why not get the ECU and the instrument cluster? That way you are covered.
Old Jan 3, 2018 | 08:07 AM
Will it be able to recognize my key fob?I’m thinking I will have to do some programming no matter what.
Old Jan 3, 2018 | 08:23 AM
I am stuck in Minneapolis at my folks, and Expedition Autowerks has Autologic and will program it for $50. So I am going to go that route. I can probably do it myself with the autocom, but am not going to risk buggering up my ECU.
Old Jan 3, 2018 | 08:28 AM
mln01's Avatar
How did they diagnose it being a BCU problem?
Old Jan 3, 2018 | 08:33 AM
abran's Avatar
Autologic can do it, but they will need to reprogram your remotes. They are synced with the BCU.
Also, $70 is a good price. Make sure they do the remotes.
abran's Avatar
I’m also suspect of the diagnosis, but it does happen.
Old Jan 3, 2018 | 09:45 AM
I just got a picture of the BCU, and after fiddling, no start, no crank. I go back over, tap it a few times, and it fires immediately.
Now, that is not a sure fire 110% diagnosis, and there is a possibility it is unrelated, but I doubt it. I will get it switched out, and programmed, see what happens. I am not sure I have any other recourse.
Old Jan 3, 2018 | 09:46 AM
Thanks Abran, I only have the one, so I will mention it.
