Neutral safety switch
Old Nov 14, 2018 | 05:13 PM
CollieRover's Avatar
Old Nov 14, 2018 | 05:15 PM
Old Nov 14, 2018 | 05:16 PM
You can see the tab in the second set of photos that I ground down to allow it to seat to the gasket.
in the first you can see how warped it had become allowing in water, and I believe letting the mechanism to slip and not engage properly.
Old Nov 16, 2018 | 10:22 PM
Have not had any recurrence of no start since rebuild.
I’d recommend an inspection of the rivets, and preventative rebuild for anyone who has not had this issue.
Really, not a terrible fix at all. I don’t see why it should not last a long time.
Old Mar 14, 2019 | 10:46 AM
After a ABS 023 Code: Gear info not valid, I put in a good used XYZ Switch. Went easier this time, and did not need to re-brush the shaft or fiddle too much.
Hopefully, the 023 will not reoccur.
Old Mar 14, 2019 | 03:47 PM
With the new XYZ Switch in it is starting better, but could also be because it is 30 degrees warmer than it has been today.
Aaron Barnes
Apr 3, 2019 10:34 AM
TRIARII
Mar 7, 2018 10:36 PM
CarolinaRovin
Mar 23, 2016 02:46 PM
cobbcj7
May 21, 2015 01:04 PM
Disco2 MTL
Dec 17, 2014 10:44 AM
