That would be possible, but quite an effort. Manual claims, just "raise the vehicle on ramp and then remove sensor". Seems impossible unless you are taller than 6'10".
How about with the front driveshaft removed from the TC side(also a small p.t.a)
That's a possibility. I will check that out when greasing the drive shaft next time.
EDIT: It is probably easier to reach when removing the handbrake. The drum blocks the access. I did the rear shaft just last summer and it was quite easy. The handbrake is just 4 more bolts.
This repair can wait. Just the "neutral" warning doesn't work, but it is good to have it.
