Neutral Switch: Has anyone tried this?
Old Jan 30, 2020 | 01:10 PM
Discorama's Avatar
Default Neutral Switch: Has anyone tried this?
It's on top of the transfer case. I can't reach it, tried from multiple positions and I am not a short person.
Old Jan 30, 2020 | 02:09 PM
Sixpack577's Avatar
Can't you reach it from inside with the center console out?
Old Jan 30, 2020 | 04:35 PM
Discorama's Avatar
That would be possible, but quite an effort. Manual claims, just "raise the vehicle on ramp and then remove sensor". Seems impossible unless you are taller than 6'10".
Old Jan 30, 2020 | 05:15 PM
Sixpack577's Avatar
How about with the front driveshaft removed from the TC side(also a small p.t.a)
Old Jan 30, 2020 | 09:21 PM
Discorama's Avatar
That's a possibility. I will check that out when greasing the drive shaft next time.
EDIT: It is probably easier to reach when removing the handbrake. The drum blocks the access. I did the rear shaft just last summer and it was quite easy. The handbrake is just 4 more bolts.
This repair can wait. Just the "neutral" warning doesn't work, but it is good to have it.
Davis31052
Dec 13, 2019 10:09 AM
yogacwgrl
Oct 16, 2013 08:39 AM
lordmorpheus
Jun 13, 2012 05:11 PM
mb13894
Jan 1, 2012 06:47 PM
Danny Lee 97 Disco
Apr 15, 2010 07:20 PM
