New alternator. Won't crank
Ok so I just installed a new alternator and charged the battery. And jus now it wouldn't crank. So I jumped it off and now it dosent want to shift right (low battery?) could I jar a bad alt already less than 24hrs old?
Anything I might be missing? I'm on the way to get the battery/alternater cheake and I'll see which is bad or both. Any advice would be great. Thanks
You will need the universal water pump wrench and the fan clutch wrench, I believe 36mm is the correct size for your truck. You can buy these, but I would check an Autozone or Napa first. Oftentimes automotive stores will have these tools available for rent or loan.
JumPeR04
12-17-2009 07:57 PM
mgabriel
12-11-2008 11:53 PM
