New alternator. Won't crank
Old Jun 3, 2011 | 11:46 AM
84crawling's Avatar
Exclamation New alternator. Won't crank
Ok so I just installed a new alternator and charged the battery. And jus now it wouldn't crank. So I jumped it off and now it dosent want to shift right (low battery?) could I jar a bad alt already less than 24hrs old?
Anything I might be missing? I'm on the way to get the battery/alternater cheake and I'll see which is bad or both. Any advice would be great. Thanks
Old Jun 3, 2011 | 11:51 AM
DarylJ's Avatar
Battery terminals/cables. Check and clean the starter/ground sides too.
Old Jun 3, 2011 | 12:29 PM
84crawling's Avatar
O'Reilly alternator putting out 8v installed yesterday :-/. Figgures. Anybody recomend a better one
Old Jun 3, 2011 | 12:55 PM
sloan74's Avatar
Bosch
Old Jul 7, 2011 | 11:14 PM
JP_SATX's Avatar
Default alternator swap
I need to swap out my alternator as well. I saw in the RAVE that I'm supposed to remove the viscous fan w/ two special tools. Does anyone have a way around this, or where can I get the tools?
Old Jul 7, 2011 | 11:22 PM
EkaInfinitos's Avatar
Last time I had to, I was able to remove the viscous fan using a pair of vice-grips. I wouldn't advise trying that, but it is possible.
You will need the universal water pump wrench and the fan clutch wrench, I believe 36mm is the correct size for your truck. You can buy these, but I would check an Autozone or Napa first. Oftentimes automotive stores will have these tools available for rent or loan.
Old Jul 8, 2011 | 05:20 AM
drowssap's Avatar
36mm waterpump wrench you should be able to loan one at autozone or advanced, dont know about Oreilly's
Disco Alan
Nov 21, 2014 09:21 AM
kleener
Jul 12, 2013 08:06 AM
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
jrsactown
Aug 17, 2006 07:44 PM
