new to board
new to board
Hello all,
I've been lurking for some time and seems like a great site......great to be here!!
Of course I have a problem with my 98 D1, 202,000 miles......I've searched extensively, but still need some thoughts. Okay, here we go:
-fuel pump won't run with the harness connected (currently hot wired to my trailer harness)
-here is the crazy stuff......I have power at the harness, 12v on the purple/white wire and 5v on the gage pins.
-turn the key to position 2 and the voltage drops to zero after 10 seconds (just like it should)
-I have power at the multifuntion relay and at the inertia switch (switch is not popped)
-all grounds that I could find are good
-all harness connections are good
-all fuses are good
-rebuilt pump with new airtex E3270 pump....
any help would be appreciated...........
-all fuses are good
-I installed a brand new pump only into the original housing
-hot wired to my trailer wiring harness (must turn lights on first then start) the pump will not operate with the harness connector attached
I guess I will go into the wheel well and jump the pump harness to see if it is that.............
Thanks for the replies..............I'll post back
