New Brake calipers
Old Apr 6, 2013 | 02:24 PM
toofaroffroad's Avatar
Default New Brake calipers
My passenger side rear caliper is seezed. It works but after enguaging the brakes I get a swqeel. Put new pads in a few months back and it was a bitch to get the calipers open. i'm replacing the caliper and wanted to varify that there is actually a difference between left and right or will any rear D2 caliper work?
Also are these calipers the same as Ranger Rover same years? Just trying yo widen my search. Thanks for any help.
Old Apr 6, 2013 | 02:36 PM
How many miles on your truck, if over 100,000 miles might consider replacing both calipers to prevent any pulling while braking.
Old Apr 6, 2013 | 04:41 PM
Bkreutz's Avatar
Left and right are different (where the fluid line and bleeder is located)). Don't know about a P38 interchange. I have to agree with Mike, I'd replace both sides. Brakes are not something you want to "scrimp" on.
Old Apr 7, 2013 | 10:00 AM
THe truck as around 150 miles on it. That is good advice. I already ordered the passenger side caliper. I'll try to get the driver side also and do it all at once.
Old Apr 7, 2013 | 10:27 AM
br0keit's Avatar
Rock auto has centric remans for like $35 after core return. they come with new pins AND brackets...mine are in the mail and going on this week.
As for your question on sidedness. There ARE specifics per side because of where the banjo bolts on and the bleed screw location because it needs to be located at highest point to bleed air properly.
I BELIEVE that the p38 RR has the same brakes as the 99-2002 D2 but the calipers were redesigned in 2003. I'm only about 40% sure about that though.
jhawk
Apr 24, 2013 10:42 PM
Sam95disco
Feb 19, 2013 08:19 AM
Cassidy Bodle
Jun 3, 2012 11:17 AM
calebbo
Jun 30, 2011 01:34 PM
welling4x4
Sep 29, 2010 11:10 AM
