new chime...
Old Mar 22, 2014 | 08:39 PM
jamestfl's Avatar
Default new chime...
I now have a chime sound anytime I open the driver's door, no key in ignition, it just starts going off. didn't used to do this and no new codes. is this indicative of an issue or is it now working properly? thanks...
Old Mar 22, 2014 | 10:31 PM
XCELLER8's Avatar
likely the ignition switch is "wobbly" and it thinks the key is still in there....does the key work ok ?
Old Mar 22, 2014 | 11:28 PM
Dane!'s Avatar
Check your light switch, maybe a connector is gunk'd up and reading that your running lights are on and chiming. Its unlikely but it happened to me, so after you check the ignition maybe try playing with your switch.
Old Mar 24, 2014 | 08:26 AM
jamestfl's Avatar
thanks guys. key works just fine, not loose or jiggly. Dane, which light switch(es) should I check?
Old Mar 24, 2014 | 02:01 PM
Shade Tree's Avatar
My first thought is that you have done something to anger the Rover Gods.
You should repeat "God Save the Queen" three times and salute the first Union Jack you see.
Good Luck
Old Mar 24, 2014 | 02:23 PM
jamestfl's Avatar
Just the words "God Save the Queen" or the Sex Pistols song with the same name?
I hate when I anger the Rover Gods. But hey- I sacrificed a transmission gasket this weekend and had lots of ATF running down the exhaust pipe, my arm, the carboard box, the asphalt, do you think that'll do for a sacrifice?
Old Mar 24, 2014 | 04:54 PM
zeroone's Avatar
It's red. It can be considered a type of blood..
dusty1
Mar 15, 2014 11:09 PM
pjvarc
Apr 17, 2010 11:21 AM
rankar
Jan 2, 2010 09:40 PM
mgood4
Jul 14, 2009 08:43 AM
btp226
Jul 2, 2006 10:42 AM
