New CPS, truck idling way too high now
Old Nov 19, 2023 | 05:23 PM
disco_nap's Avatar
Default New CPS, truck idling way too high now
I had a new CPS installed — shop did it because I broke the connector on the ECU wire. They spliced in a new connector in addition to the crank sensor.
The truck is now idling at 2000rpm.
i just picked it up on Friday and haven’t driven it otherwise until today (Sunday)
Does the ECU need time to adjust to the new sensor?
Old Nov 20, 2023 | 07:32 AM
Best4x4's Avatar
They might not have put everything back properly. Could be a vacuum leak. I always recommend getting the adaptions reset whenever you work on your D2.
Old Nov 20, 2023 | 09:36 PM
disco_nap's Avatar
Well, oddly enough, it is now back to normal. I went for a few drives yesterday and today and after the third one, it was back to idling normally. Been consistent since then too.
Old Nov 21, 2023 | 09:41 AM
ahab's Avatar
Ideally you reset the adaptive values when swapping those parts so the ECU "forgets" all the minor compensations it was making in its relentless quest for efficiency (!). I don't know that high idle would be a result of not resetting it, but it sounds like the ECU has relearned on its own and you're back to normal.
Old Nov 21, 2023 | 09:59 AM
disco_nap's Avatar
Any idea if that reset be done with a nanocom? I was a little premature in declaring success yesterday. I went for a drive in the evening and it shot up to 2k when I started it, but eventually settled down to 800 or so.
Old Nov 21, 2023 | 10:18 AM
ahab's Avatar
I'm not qualified to comment with certainty but my guess is yes. I'm pretty sure I've seen the option in my Foxwell and it's a toy compared to the mighty Nanocom. One of the elders here will have the answer.
Old Nov 22, 2023 | 01:17 AM
Dervish's Avatar
Might be a longshot, but hows the throttle cable adjustement?
Old Nov 22, 2023 | 01:26 PM
JUKE179r's Avatar
Did they install a Bosch CPS?
I installed an aftermarket CPS and the damn thing made my D2 rev up high and lurch forward during traffic stops. It was the weirdest ****. It was the only part I replaced so I knew that had to be the culprit.
Replaced it with a Bosch CPS and all has been well ever since.
Old Nov 22, 2023 | 03:58 PM
Best4x4's Avatar
Nanocom can reset adaptive values & yes Bosch CPS is the only way to go. Generic units die quickly.
MRZ
Feb 9, 2018 04:55 AM
moosejr
Sep 29, 2016 10:58 PM
gforce1108
Oct 21, 2013 12:39 PM
Extinct
Apr 24, 2013 07:21 PM
wayne johnson
Jan 24, 2012 03:59 PM
