New Disco II owner
New Disco II owner
So I finally got my Land Rover!! I've had it about a two weeks now and I'm starting to really sort it out finally. My wipers are acting a little odd. On the intermittent setting they stop at random places throughout the stroke. In the fast position they act properly. Any idea what might be going on here?
on
Can be caused by a bad wiper switch and sometimes by a bad/failing park switch in the wiper motor that will stop the wiper when being turned off, at any spot of the windshield.
So what year truck did you buy, how mechanical are you? If you like to do your own work, might want to read my major service list posted at the top of this section and do it all, especially the rebuild/replacement of the front drive shaft before it fails.
Thanks everyone. I got a 2000 Red with the 4.0L with 115k on it. I'm planning on going through all of the major service stuff one item at a time. I'm fairly mechanical and will probably be doing most of it myself. I think it's probably the switch and not the parking one. It stops midstroke while the wipers are on, not just parking in the wrong spot.
Number one item you need to focus on is Replacing your front driveshaft w/ the newer updated serviceable u-joint one.
Like Bacardi and Cola...Do it Do it.
Yeah I saw that in the threads I've been reading. I slid underneath and it looks like the front shaft is the type that doesn't have the grease fittings so I think that will be the first thing I fix.
Other things on the list:
Find and replace relay for Aux lights
clean/replace wiper switch
rear ladder install
high clearance front and rear bumpers
replace pass side tsignal
and install the linkage for the cdL
are there step by step guides for this one?
rear ladder install
Run33
05-11-2015 09:43 PM
kayak74
01-23-2013 07:13 AM
MuddMouth
09-30-2010 10:30 PM
