New disco owner
Also, do the PCV mod asap. Get religious about checking your coolant level frequently.. More description on you truck and service history. After living with these for the better part of 4 years and 12 truck I would say depending on what has been changed already I would recommend you replace the entire cooling system, radiator, water pump, coolant tank, and all hoses. You will likely replace half of them when they fail anyway, just do it preventatively and you may avoid an overheat and the resulting head gasket job. Also, check the driveshaft immediately for grease joints at both ends - search the forums for it.
CollieRover (08-19-2019)
Cj7jed@gmail.com
04-06-2016 08:44 PM
