New Discovery Owner Questions-Snorkel & Lift Kit)
You can use the D1. It is plug and play so long as you take everything involved with the shifter. You will need the shifter, boots, console cover, linkages, nuts/bolts, grab everything or you will have problems. Most important for a seamless swap is the cover and lever for HI/LOW. I tried to find a picture but no luck. Because of the linkage from the D1 shifter to the Hi-Low lever, you will need that lever as the D2 lever doesn't reach over as far. If you do a few searches you will come across what I'm trying to explain.
clandrovers
Oct 21, 2012 10:34 PM
MuddMouth
Sep 30, 2010 10:30 PM
