New Discovery Series II Enthusiast In Houston
Old Feb 8, 2013 | 09:26 PM
Dgosh28's Avatar
Originally Posted by jhill15
$2600 is a good price. I would pay it for an 01, and you might luck out with the nipple on top of the transfer case to lock the diff. $500 mod and your truck will crawl up a brick wall. Check it out, just reach up on the top of the front output of the t.c. and feel for a bolt sicking up on the right side. If its there you will know if not then the t.c. will be smooth. From my understanding in 01 you have a 50/50 shot of having it.
Thank you for the feedback. I will crawl under there this weekend and post the results. Is it possible to tell from the VIN#?
Also, a guy from the Benzworld site offered to send me a pair of Old Man Emu springs for my truck for free. How do they affect the performance/ride?
This is my first 4X4 so forgive me if I ask stupid questions.
Old Feb 8, 2013 | 09:29 PM
That is the thermostat. Here is how it works; hot coolant from the "T" enters thru a metering disc with small holes. That mixes with colder fluid from the radiator. This mixing warms up the main body of the stat and opens, sending more coolant out the side hose to the water pump. A new 180F stat (warm weather) from Atlantic British or other on line vendors is a great improvement. At idle, when cold, the metering disc descends to allow more coolant to warm up the heater. Once main stat opens, it shoves the bypass disc back up and only hot metering flow comes that way.
There are no stupid questions, even on Jeep forums.
Attached Thumbnails New Discovery Series II Enthusiast In Houston-land%252520rover%252520thermostat%252520005.jpg   New Discovery Series II Enthusiast In Houston-d2-stat-internal.jpg   New Discovery Series II Enthusiast In Houston-d2-stat-internal-2.jpg
Old Feb 8, 2013 | 09:32 PM
Rover_Hokie's Avatar
Since you are in Houston, I would definitely recommend you swap out that stock 195 degree thermostat for a new 180 degree thermostat to help keep your coolant temps down. I lived in Sugarland for a while. Welcome aboard.
Old Feb 8, 2013 | 09:49 PM
Full disclosure - I took a promotion and move to Houston, in the early 80's; did 320% of quota, so they moved me back to Atlanta to help out there. Enjoyed my year there, lived off FM1960, and SWMBO and I actually got a promo flight on the Goodyear blimp which was based nearby at the time. The one thing I recall about Houston's infamous traffic was that people just made their own exit ramps where needed from the freeways. And you started running your AC in January.
Old Feb 8, 2013 | 09:55 PM
Dgosh28's Avatar
Thanks guys. I'll order the new thermostat this weekend. Am I safe assuming the green coolant is correct? The recovery bottle kinda looks like it might be stained orange, but I doubt this truck had Dexcool in it. As a matter of fact, I am certain the previous owner just topped off with water when it was low.
Also, when I first start the truck and the engine is cold I hear a fairly loud sound like some sort of fan or pump on the passenger side behind the dash. After 2 or 3 minutes it goes away. Is that normal? Any ideas what it could be?
Old Feb 8, 2013 | 09:59 PM
Dgosh28's Avatar
You do know our fair city.
I was teasing some friends in New England about the cold snap they are having now and mentioned that it was going to be 78 here today. They will get their revenge in a couple of months though when they have the tops down in their convertibles and it will be 100 here with 95% humidity.
Old Feb 8, 2013 | 10:01 PM
jhill15's Avatar
Originally Posted by Dgosh28
Thanks for your help. I will check it out tomorrow. Can you tell me what #16 is? That is the "bottle" that had the disconnected hose when I picked up the truck. The very end of the plastic tube was broken off inside the hose, but after I removed it I was able to get the hose back on and it seems to be holding fine.
That's your thermostat. Its different then most vehicles that have the tstat on top of the block
Old Feb 8, 2013 | 10:06 PM
Dgosh28's Avatar
Looks like the warm weather thermostat is out of stock till 2/14 at AtlanticBritish. I asked to be notified when they are in stock.
Old Feb 9, 2013 | 05:55 AM
Dgosh28's Avatar
Since Atlantic British is out of stock on the warm weather thermostat I looked on eBay and found the item by brands Eurospare and Motorad. I'm not familiar with either brand and the Atlantic British site doesn't list a brand name. Do you have a brand preference? I know in my other life there are brands that the forum members will avoid at all costs. I don't want to get the wrong one.
Thanks again for all your guidance.
Old Feb 9, 2013 | 06:38 AM
JoeLena's Avatar
Yes, what is that? Curious about it since my 2004 is the same.
