New Discovery Series II Enthusiast In Houston
Old Feb 9, 2013 | 07:04 AM
  #21
That electric fan noise at start up also happens on vehicles equiped with secondary air injection, or SAI. You'll have metal "gas pipe" flex hoses around the manifold. Normal to run, but noise indicates bearings going. There is a filter inside it that can be cleaned out.
Another Houston fun fact, they never gave the humidity on the weather report. Always 95% + I guess. So now I'm in the Savannah area, flat, same weather, hurricanes, and nothing inland for hundred miles plus. Coastal livin', no chillin'.
Many have posted on here about installing the Motorad. I'm old school, I like to boil my thermostats and see it open with my own eyes. With SWMBO approval of pan, I'm only approved to scrub them.
Old Feb 9, 2013 | 07:58 AM
  #22
Dgosh28's Avatar
Is it possible to use a conventional thermostat with these trucks? I saw a website that listed the "traditional" ones as the only options. I don't think my truck is equipped to accept the traditional one.
I'll put checking the SAI filter on my to do list for Monday. Thanks.
Old Feb 9, 2013 | 08:05 AM
  #23
jhill15's Avatar
Originally Posted by JoeLena
Yes, what is that? Curious about it since my 2004 is the same.
I too am curious. What the heck is that. Blower motor...maybe? Idk
Anybody know?
Old Feb 9, 2013 | 08:23 AM
  #24
JoeLena's Avatar
Thank you! So if I can hear it, it is bad? It's like a humming, not a bad sound, like bearings squealing. I'll look inside and see how that filter looks.
Old Feb 9, 2013 | 11:57 AM
  #25
SuperSport's Avatar
They DO hum quite loudly. It sounds like a portable vacuum running for a minute or so, then it turns off. Should only come on during a cold start in the morning, or I guess whenever it's cold enough.
Old Feb 9, 2013 | 01:32 PM
  #26
JoeLena's Avatar
That's it exactly. Only when it's cold.
Old Feb 9, 2013 | 01:43 PM
  #27
Dgosh28's Avatar
Look at the hoses that supply coolant to the throttle body heater. It is item 5 on the picture. Any small line under the hood and nipple it connect to will be brittle.
You were exactly right on your diagnosis. Looks like the outbound most hose was leaking. Of course, I broke the plastic line in about 4 pieces. Also, I have no idea how to remove the funny clamps used. I sure hope the dealer is open so I can pick up parts today. I doubt Autozone will have this plastic line. The throttle body is filthy also. What do you recommend to spray in there to clean it? I used some mass air flow sensor cleaner, it the results were marginal.
Old Feb 9, 2013 | 02:32 PM
  #28
SuperSport's Avatar
Autozone carries Throttle Body Cleaner. That and a Very soft rag will do. Don't scrub hard.
Old Feb 9, 2013 | 03:16 PM
  #29
Dgosh28's Avatar
Thanks
Old Feb 9, 2013 | 03:25 PM
  #30
Dgosh28's Avatar
Drove almost an hour to get to the dealer to find out the parts dept closed 15 minutes earlier. I did find out though that the throttle body gaskets leak. That may actually be my problem. I wish I had known that prior to breaking this coolant line.
Looks like I better replace the gaskets and the plate along with the line and then I'll be fine. Much better news than head gaskets. Good thing I ran into the Service Manager.
