New Drive Shaft Contemplation
Old Apr 18, 2009 | 09:33 PM
Night Train's Avatar
This is what I did, I got a Tom Woods - it came in, I swapped it out in something like 45 minutes. Then I took the stock one to a driveline shop and had it rebuilt and balanced and now have a spare to use if and when I have to rebuild Toms.
Old Apr 19, 2009 | 12:07 AM
AK Rover's Avatar
A spare drive shaft is never a bad thing to have, especially if you do any off roading. When I get around to upgrading my axle and drive shaft I plan to keep the originals as trail side emergency fix parts.
Old Apr 19, 2009 | 01:38 AM
jeffrudy's Avatar
thanks.. thats more then likely what ill end up doing, or ill end up selling the old one. kno i just need to find a way to get it by the wife hmmm....
Old Apr 19, 2009 | 06:44 AM
antichrist's Avatar
Originally Posted by jeffrudy
im still worried about the front drive shaft though.....
The main issue with the stock front propshafts on the DII is that the DC joint can't be lubed, the cats bake the grease and then the u-joints fail.
If you rebuild it with u-joints that have grease fittings you should be fine provided you lube it every oil change (u-joints should be lubed every 5,000 miles with normal use, but I find it easier to remember it as part of the oil change). And that means really lube it, not "Yeah, I'll get to that next week". Good intentions don't count. And you should see new grease come out from around all 4 seals on each u-joint.
If you don't lube them properly (often enough and with the correct amount of grease) you're better off with sealed u-joints, they'll last longer.
Old Apr 19, 2009 | 10:21 AM
Originally Posted by Disco2Fever
I'm pretty mechanical, Mike... I mean, I don't know how one rates himself, but I do brakes and plugs and wires and stuff. My biggest job so far was removing and replacing a 700r4 transmission in a 1992 GMC, but it took me two weeks and a lot of reading to do it. And, I sort of messed up the way the dipstick went in... but I didn't leak, and it worked fine afterwards..
ANWAY-
Please do send me the pdf! You should have my email address, but please let me know if you need it.
Thanks, Mike. I might just try it myself... I just don't want to mess it up.
E-mail me your e-mail address and I'll send it out to you.
Old Apr 19, 2009 | 12:09 PM
AK Rover's Avatar
Talked to a guy in the gun shop one day and he said that he and his wife had a rule that once something is in the house it got to stay. So he was buying another gun while she was having her hair done. Sounded like a good rule to me.
My oil change interval is 5000 miles so it makes it really easy to remember to grease the u-joints every 5000 miles.
Old Apr 19, 2009 | 06:50 PM
jeffrudy's Avatar
ahahah i have a gun addiction too so i think ive used that one up
Old Apr 19, 2009 | 10:48 PM
AK Rover's Avatar
There are advantages to being single. Only person I have to justify buying more guns to is me. Even at that it took me quite a while to justify my AR15.
Old Apr 20, 2009 | 10:08 PM
jeffrudy's Avatar
theres a nice new sako trg-42 .338 lapua in my closet right now
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
dnorrell
Mar 31, 2010 07:50 PM
Ruffin' It
Jun 2, 2009 11:13 AM
Disco2Guy
Mar 9, 2008 02:10 PM
