New driveshaft time
Old Nov 22, 2012 | 06:53 AM
  #61
antichrist's Avatar
Originally Posted by turbodave
Isn't the grease zerk on the RH of the double-cardon in the "less than optimal" orientation in the ebay driveshaft? It sure looks that way given the red grease blob.
Yes. In reality on a 1310 in a Land Rover it probably doesn't matter, but that's the sort of attention to detail (or lack thereof) I look for when buying something. More important to me than spelling, though spelling is a sign also. Spell check isn't that difficult.
Old Nov 22, 2012 | 07:20 AM
  #62
turbodave's Avatar
Originally Posted by lr2001silver
If you brought me your drive shaft and asked if we could check it? Balancing would be no more than $30 at max. It sounds like you did your rebuild in depth compared to most! The GKN & moog ball should not cause you any problems. But more than likely you will need to get it re-balanced after a true rebuild.
Thanks for the heads up.
Dave
Old Nov 23, 2012 | 10:49 AM
  #63
Dan7's Avatar
Silver used "a" instead of "an" before a word starting with a vowel in an earlier post. He must know nothing about drive shafts!
Old Nov 23, 2012 | 11:04 AM
  #64
lr2001silver's Avatar
Banned
Thanks Dan hahaha
Old Nov 26, 2012 | 10:35 AM
  #65
Dan7's Avatar
Got the driveshaft (a while ago...3 days after ordering) and installed yesterday. Came pre-greased, heavy duty (compared to stock), and with all 4 zerks on the same side! Aside from the paint job locking up the center sleeve (would not extend...1 generous tap on the ground solved), it installed w/no surprises. Drove to 75 mph...smooth as Garry Coleman's chin!
Old Nov 26, 2012 | 10:39 AM
  #66
Dan7's Avatar
Any ideas on what to do with the old one?
- 1 legged barstool (will take 2 more donations from St Louis area)
- Mount mirror on 1 end for flexible bathroom tool
- 2001-2012 tax return paper weight
- Strengthen your swinging arm during baseball practice
Old Nov 26, 2012 | 11:02 AM
  #67
ZGPhoto's Avatar
Don't skimp on the drive shaft!
Old Nov 26, 2012 | 11:26 AM
  #68
Slingin Carbon's Avatar
Hey Silver I have not forgot about your PM... I just have not had time to contact you with the Holidays. Plus, I really do not know what Drive Shaft I have! I don't know if it has ever been changed, and if not (I really do not know what to look for to determine if it needs changed). I will be in touch very soon!
Old Nov 26, 2012 | 11:35 AM
  #69
Dan7's Avatar
Look at the U-joints. Are they all greasable? If not, it doesn't matter if it's a stock driveshaft or not, it needs to be replaced.
Old Nov 26, 2012 | 11:37 AM
  #70
CoastieDisco2's Avatar
While on this subject; does anyone know the size and specs of the bolts and nuts for the prop shafts? Thanks!
