New driveshaft time
Old Nov 26, 2012 | 11:47 AM
  #71
Slingin Carbon's Avatar
Dan... You are really talking to a DUMMY when it comes to most major mechanical. I can do some stuff, but drive shafts are foreign to me.
Old Nov 26, 2012 | 02:49 PM
  #72
lr2001silver's Avatar
Banned
Originally Posted by CoastieDisco2
While on this subject; does anyone know the size and specs of the bolts and nuts for the prop shafts? Thanks!
With me you have no worries! I include the ny-lock nuts with my drive shaft
Wanna buy 1?
8 ny-lock nuts & 8 grade 8 or 3/8" bolts w/ 24TPI
Old Nov 26, 2012 | 07:37 PM
  #73
antichrist's Avatar
Originally Posted by Dan7
Silver used "a" instead of "an" before a word starting with a vowel in an earlier post. He must know nothing about drive shafts!
Interesting you're focusing on what I said was the much less important, but since you have, there's a big difference between an off the cuff comment in a forum and a published advertisement.
Old Nov 26, 2012 | 07:53 PM
  #74
antichrist's Avatar
Look at the U-joints. Are they all greasable? If not, it doesn't matter if it's a stock driveshaft or not, it needs to be replaced.
You can't base it solely on if it's greaseable or not. A u-joint with zerk fittings that hasn't been greased in 20,000 miles is likely in worse shape than a sealed u-joint with 3 times that mileage.
If you don't know for a fact the u-joint has been lubed at least every 5,000 miles, and lubed correctly, then it should be replaced.
Old Nov 26, 2012 | 07:54 PM
  #75
antichrist's Avatar
The stock bolts are grade 5. Ideally you don't want to mix grades.
Old Nov 26, 2012 | 09:11 PM
  #76
blamo's Avatar
I found anticrists post on pt #s & rebuilt both my drive shafts do less than $100 clams & an afternoon of labor well worth it thanks for info anticrists !
Old Nov 26, 2012 | 10:53 PM
  #77
Banned
Then you still need to take it to get balanced.... also the whole set-up and tube used is
Weak and can twist and break. Flanges can bend and balance can be thrown off a used factory drive shaft for these trucks is a paper weight or as stated a unique bathroom tool if your into things like that.
Old Nov 26, 2012 | 10:58 PM
  #78
ZGPhoto's Avatar
Look guys, you can rebuild your driveshaft, it IS possible, and many do it. If you stay on the road and use the DII to buy groceries then the rebuilt stock unit is perfect. If you want it to last longer, and want to go off road, buy an upgraded unit.
Old Nov 27, 2012 | 05:04 AM
  #79
blamo's Avatar
I did not have to re balance mine no vibe , I don't have 35s" or lockers I don't think the front propshaft is the weakest link , just sayin I've got plenty of things to throw my benjies at. Good luck , blamo
Old Nov 27, 2012 | 07:15 AM
  #80
antichrist's Avatar
The stock propshaft is fine for probably 90% of drivers if it's properly maintained. Face it, Land Rovers aren't super high torque power houses.
265,000 miles on my '95, run 7.50x16's and I beat it off road and am not a gentle driver on the road. 3/4's of that is with a DII front prop.
