New everything and now no oil pressure, WTF??
Old Jan 11, 2018 | 06:46 AM
  #21
Davis31052's Avatar
Speakingof the upper end of the motor (engine), and inspection the valve train. Who hasfound wear that was readily identifiable on rocker arms, and shaft? Any pics that you could post for comparison?
Iknow when I had my assemblies apart earlier this fall that the rockers shaftshad some obvious wear where the rocker arms pivot but not to the point to wherethe rocker shaft was loose. I also verified I had no bent push rods and thetips, both top and bottom looked the same across the whole lot. The push rodcup on the rocker arm and the pad on the valve stem side were in place and wearwas even across the board.
So,what’s the “go, no-go” indicator for these parts in your opinion?
Jwehking
Aug 25, 2017 08:44 PM
Broken08
May 16, 2015 01:39 PM
redmanxi
Nov 7, 2013 01:34 PM
humroot
Jun 15, 2009 01:32 AM
