new front drive shaft
Will either be on the end caps of the U-Joint or on the inside of the u-joint in the center where it comes together. There should be one on the shaft as well. Also, the correct way to grease a u-joint is to pump in the grease until the rubber seal bulges, not until the grease oozes out from everywhere.
(I should edit this to say "Until grease gushes out, a little oozing out is ok." What you are trying to avoid is blowing the seals.)
DiscoJon
07-14-2019 01:51 PM
TripleThreat
04-12-2011 08:58 AM
Ruffin' It
06-02-2009 11:13 AM
