new front drive shaft
Stupid question: Just had my front drive shaft rebuilt about 8 mos ago, and was told that it was made to be greaseable...(here goes) Where would i look to find the area/zerk fitting or whatever to grease it up?
thanks
thanks
Will either be on the end caps of the U-Joint or on the inside of the u-joint in the center where it comes together. There should be one on the shaft as well. Also, the correct way to grease a u-joint is to pump in the grease until the rubber seal bulges, not until the grease oozes out from everywhere.
(I should edit this to say "Until grease gushes out, a little oozing out is ok." What you are trying to avoid is blowing the seals.)
A helpful tip I learned from my local Driveshaft rebuilder - Drive the vehicle and get the joints warmed up before you grease them. My problem was that if I greased them when cold the grease would not flow evenly through all 4 bearings. It wants to take the least restrictive path.
There are two places the zerks might be.
Read this:
https://landroverforums.com/forum/ge...rebuild-29302/
The part under :Checking to see if yours has been rebuilt
Read this:
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
Ruffin' It
Jun 2, 2009 11:13 AM
