New Front Mud Flaps Install.
Old Mar 12, 2010 | 03:01 PM
2001SE7's Avatar
Default New Front Mud Flaps Install.
Hi all,
I have removed the mounting bracket from the truck to pre-install the flap on the bracket and then re-install the bracket. My problem; most of the body bolts broke off removing the brackets. I can't tell how the bolts are fastened to the body. Kind of looks like they may have been welded. What I want to do is lift up the carpet and see if they are possibly a simple replaceable bolt. Has anyone here performed this already? Please share your knowledge. Thanks.
Old Mar 21, 2010 | 07:38 PM
2001SE7's Avatar
Default Lets not all try to talk over one another here.
Please, Please, form a single line with all these replies.
Old Mar 22, 2010 | 08:22 AM
XCELLER8's Avatar
OK....I'll chime in.......LR likes to use what I'm going to call a "crush nut" in a lot of places, at least thats the way it is on my '98. It's a round alluminum nut that goes into a hole and then when the bolt is tightened it crushes down and secures itself to the hole, the bolt can then be removed and reinstalled, UNLESS....it all corrodes together as has happened with many of us. The easiest fix is probably to drill out enough of the old ones to get a new bolt through them, not sure about yours ...but you could possibly get a new bracket welded there ...maybe a little re-engineering ?
Old Mar 22, 2010 | 08:52 AM
okdiscoguy's Avatar
They are carriage bolts in from under the carpet.
Spencerfitch
Dec 17, 2010 10:48 AM
tshirttom
Jan 21, 2010 10:26 AM
EASTLAND
Feb 6, 2008 07:22 PM
Lilsallyan
Jun 5, 2006 10:54 PM
jabellas
Jun 24, 2005 03:26 PM
