New Guy, New Questions
Old Mar 26, 2015 | 09:26 AM
  #21
dusty1's Avatar
my 1st d2 had 2 bolts totally missing from the vale covers....Loctite is a good measure on these tiny little guys. helps combat the vibration
Old Mar 26, 2015 | 09:42 AM
  #22
drowssap's Avatar
12 point iirc
Old Mar 26, 2015 | 09:43 AM
  #23
dusty1's Avatar
true that^
Old Mar 26, 2015 | 01:17 PM
  #24
robert.juric's Avatar
I take it 8mm 12point is not a common pattern, none of my socket kits have 8mm in a 12point and when I browsed quickly at the local store I only saw 12point go down to 10mm.
Old Mar 29, 2015 | 08:38 PM
  #25
Fallstaff's Avatar
Much to my surprise Lowes has them here in Canada.
And watch your torque. They're in aluminum and you can only strip them once. Check the RAVE for the proper setting.
Old Mar 29, 2015 | 11:53 PM
  #26
dr. mordo's Avatar
The RAVE says, 6 ft/lbs, but the common practice is 10 ft/lbs and check them every oil change as they will loosen.
The 12pt 8mm socket was actually included with my truck. The previous owner made a point of saying "you'll need this, it's for the valve cover gaskets".
Tim P.
Dec 25, 2012 05:08 PM
SJRover
Jun 15, 2009 05:19 PM
Desertdualsport
Oct 16, 2006 11:21 AM
Doral300sc
Jan 12, 2006 12:48 PM
