New guy problems
Old Nov 22, 2013 | 04:19 PM
Shayark's Avatar
3rd Gear
Default New guy problems
Hi I have a 2003 land rover discovery. Drove it to Lowe's ran fine, came out started it and it began spitting and sputtering. She would barely move like if I touched the gas it would die. It would kind of chug along in drive at an idol pace. I had it towed home. Was told to change the fuel filter have searched the it from head to toe including removing the fuel pump to see if maybe it was in the tank... So if it anyone knows where it may be? Or has any advice i am all ears. I searched for fuel filter locations on the forum couldn't find any threads but probably messed that up as well.
Old Nov 22, 2013 | 04:48 PM
dusty1's Avatar
Thinking Filter is incorporated with the pump back there. It is probably not the filter. You should check the pressure before all that. You can use a tire pressure gauge on the fuel rail
Old Nov 22, 2013 | 06:40 PM
Shayark's Avatar
3rd Gear
Thanks Dusty much appreciated I have the pump out already think i shall attempt a swap and if that fixes her Ill know
Old Nov 23, 2013 | 02:32 AM
acg's Avatar
acg
Old Nov 23, 2013 | 07:51 AM
san988's Avatar
Thank you for the link to the video. It well documented. Now, did you get your issue resolved?
Old Nov 26, 2013 | 11:49 AM
Shayark's Avatar
3rd Gear
Thanks guys i changed the pump,... Changed nothing still sputtering barely idols or dies any other thoughts I am up to try anything.... Its gonna be hard to get it hooked to a computer gonna have to have it towed.
Old Nov 27, 2013 | 05:36 PM
T.J.'s Avatar
I thought this thread was about relationship trouble.
Old Nov 27, 2013 | 06:18 PM
xxdoylexx's Avatar
so if it sputtering the check engine light be on. if the check engine light is on your engine is giving codes that will hint at what the issue is. go to the auto parts store and rent or buy the odb2 scanner and read those codes. write them down and post them here.
AS disco Mike would say "what are the codes?"
sputtering means bad air, bad spark or poor fuel supply. It can also mean the sensors that measure and monitor the big three are not working properly.
98D1Chap
Mar 6, 2012 10:16 PM
tmodler
Apr 15, 2010 09:02 PM
travis.mara
Feb 13, 2009 09:41 PM
parks
Feb 23, 2005 04:11 AM
parks
Jan 31, 2005 12:21 PM
