New Head Bolt Question - Not what you're thinking
2004 DiscoII
So on both heads I have the top inner three bolts stamped with AA on top and 10.9 at the bottom. Not on the 2 top outside bolts on either side. Weird. On the bottom bolts I cant really tell since they are a little corroded.
Are these original head bolts? Does it mean anything?
The bolt that has 10.9/AA is the longer bolt that goes in the middle and the other 10.9/UNC DYTSA with a different designation is the shorter ones. Once you have the set it will come with longer and shorter ones that will match your application. You can cross reference them but Im sure it does not matter. Both 10.9 must be more specific with torque designation and the rest could just be the size.
twin6 (02-18-2017)
