New head gaskets! New Noises!
Old Oct 1, 2009 | 08:07 PM
bikingteacher's Avatar
Default New head gaskets! New Noises!
So I picked up the Disco today with its new head gaskets. My $1,000 quote became a $1,800 job. That included a new water pump. So if it fixed it, well, okay.
My new noise seems to come from the fan when it is kicking in and running. Is this bad--can it be silenced, or is this just "character"?
Old Oct 1, 2009 | 08:25 PM
lipadj46's Avatar
$1000 head gasket job is not realistic I'm sure people here gave that advice. What is the new noise? Also make sure they changed your oil and filter.
Old Oct 1, 2009 | 11:45 PM
grussell's Avatar
My fan is very loud, did you not notice it before or is it louder now?
Old Oct 2, 2009 | 03:17 AM
I am am worried about the chirping cricket like noise that it makes. Is that what it is supposed to sound like? Before the Head Gaskets it did this a little. I haven't been running hot even before the gasket job--that was meant to be fix the leak. While I had a leak--it was small and I did not want to wait to find a bigger leak. Is the fan noise indicating that this thing is failing? Does the viscous clutch just sound like this normally?
Old Oct 2, 2009 | 09:35 AM
Go straight back to the shop and find out what is going on, should be their responsibility.
Old Oct 2, 2009 | 03:52 PM
As the bi-metal spring on the fan clutch lock up and then releases it will make noise, it should not be noticeable, but I suppose if you have good hearing and your engine is really quiet you can hear it.
Here is some info for you.
http://www.aa1car.com/library/cooling_fan_clutch.htm
wisconsinoverlander
Oct 1, 2012 09:34 AM
RROJ
Mar 26, 2011 02:37 PM
askewm
Dec 23, 2006 11:03 PM
Desertdualsport
Oct 26, 2006 01:12 AM
spiderfreak80
Mar 16, 2006 03:19 AM
