New (and hopefully final) engine build.
Old 04-08-2023, 01:08 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
I've used ARP & TTY equally over the years & I've seen pulled threads on TTY installs as well.
Old 04-08-2023, 02:36 PM
Harvlr's Avatar
I’ve only used TTY’s and I’ve only done 2 HG jobs on my LR’s. I would have expected that TTY’s would be more prone to pulling threads though, with the huge torque that’s used compared to ARP’s.
Old 04-14-2023, 05:31 PM
Tony Luna's Avatar
Been cleaning her up a bit since she’s been down.
New OME medium duty springs and Bilsteins all around. New shock towers and isolators too.
I had the steering box rebuilt by Straight Line Steering in San Jose. Cleaned out the PS reservoir and got new PS lines. New steering and drag links. Also replaced the panhard rod and Watts linkage bushings.
Also have a spare set of radius arms at a local shop getting re-bushed.
Oh, and lots of cleaning and "rattlecan restoration"...
The following 4 users liked this post by Tony Luna:
ahab (04-24-2023), jastutte (04-25-2023), whowa004 (04-24-2023), YETIX (04-15-2023)
Old 04-15-2023, 03:48 AM
Gripen's Avatar
That is incredibly clean.
Old 04-15-2023, 06:44 AM
Tony Luna's Avatar
Had her since ‘04 - mild CA climate.
Old 04-15-2023, 05:43 PM
The_OGCJR's Avatar
It’s very pretty. You should polish that upper manifold! I mean if you like torture like myself 🤣
Old 04-15-2023, 06:36 PM
Gripen's Avatar
I recommend vapor blasting to make it easier. Leaves a nice satin finish. Just got to make sure that the runners aren't gunked up, otherwise the media used embeds itself into the sludge and now you have to take the time to scrub it all out.
Old 04-15-2023, 07:37 PM
Tony Luna's Avatar
I just need to get the damn thing running!
YETIX (04-15-2023)
Old 04-15-2023, 09:37 PM
Tony Luna's Avatar
Old 04-24-2023, 02:33 PM
Tony Luna's Avatar
Back on track!!!
After much pondering and debate, I finally chose a route forward on how to fix the stripped head stud threads in the block. Details in different post - https://landroverforums.com/forum/di...hreads-116743/
Got both heads installed with a nice solid feel on the last round of torque (70 ft/lbs).
Got the exhaust manifolds painted and cured during the wait…
The following 3 users liked this post by Tony Luna:
hasullivan (04-24-2023), whowa004 (04-24-2023), YETIX (04-24-2023)
Quick Reply: New (and hopefully final) engine build.
